Old 06-03-2008, 07:33 PM   #5
Toledo FJ
Toledo FJ's Avatar
Member Number: 14676
Re: Got my air tank in!
Ok so I just figured out how to post pics that aren't thumbnails! So here are are a couple pics of where I mounted the tank and compressor. We have to finish the wiring and plumbing this thursday, but it should be pretty easy as we have already routed most of the wiring.
So, here is the bracket you have to cut off if you want to mount the tank here.
I put the compressor in the rear over the drivers side wheel. I know they get hot, but it will be less likely to fail here than under the truck where it would be exposed to the elements. I also bought a fabric heat shield that I can place behind it if it starts to get really hot.
Drilled out the rear light access panel to run the hose and wire under the truck. I'll probably stick a rubber grommet in the hole just to make it really clean. But it looks fine as is... pretty much out of sight.
I am still trying to decide on where to mount the pressure gauge and on/off switch. I got a toggle instead of the switch that came with it. Easier to drill a circle than a square.
Toledo FJ is offline   Reply With Quote
