Old 06-05-2008, 01:04 PM   #10 (permalink)
crestwood36
crestwood36's Avatar
Member Number: 17104
Send a message via AIM to crestwood36
Re: URD short throw shifter????
Part of this has to do with the loss of leverage you get by extending the stem. By doing this you are moving the distance of the fulcrum (pivot point of the shifter) away from the load (transfer case), which results in more force required to change gears.
The reason many of us use a weighted shift knob is to counter this loss in leverage. The momentum gained by adding weight reduces the force required to shift.
And you thought physics was just for figuring out if a bowling ball or golf ball would hit first if dropped from the same height
"The ultimate goal of the educational system is to shift to the individual the burden of pursing his own education. This will not be a widely shared pursuit until we get over our odd conviction that education is what goes on in school buildings and nowhere else."
John W. Gardner
crestwood36 is offline   Reply With Quote
