VoodooBob previously said:
Do you have a drawing/sketch of how you want to lay things out in back? I'm having an "opportunity for improvement" trying to picture it...
If you're going to the Summit, it should be installed by then... It's a rigid endoskeleton made of 1" DOM tubing that is designed primarily to hold gear. It's not a roll cage. However if you think of a tubing box in the very back/cargo area you'll be right on the money. COWBOY4x4 is doing the work on it through his company Overland XT. It will have at least one Springtail MPAC rack (the one designed for the Jeep TJ) mounted on it. The Scorpion Mount will be able to mount two of the Jeep TJ MPAC racks on its rigid framework.
