Sharp3502 previously said:
I had ordered the beads when I thought I was getting the KM2's, so I ordered the 10oz bags. I ended up changing my tire order to the All Terrains which are smaller and only require 8oz according to the website. I should have an extra 2oz in each tire more than they say is required.
My truck drives perfect now, so I'm not gonna go to the trouble of pulling the tires back off. If it ain't broke, don't fix it.
Don't get me wrong, I'm not saying that they don't work. I honestly don't know if they are working or not. There is just no way to find out unless I tear everything back apart, and I wouldn't ask the tire shop to do it. They have helped me enough already.
Sharp, the problem I have with traditional weights is that they either fall off or I'll spin the tire on the rim. When I spin tire on the rim, it's no longer balanced. Since I need to run low pressure, spinning is a lot more likely to happen to me. I run low teens or 12 psi when I off road. I know what you mean about don't fix it if it ain't broke. These beads make you wonder because they are kind of spendy.
