mtnkraut previously said:
Steve 2 dummy questions. i got an add a fuse to hook up my CB. which of 2 slots do i put the fuse into? and also the fuse does not want to go in past the wedge on the prong. is it supposed to go hard and how do i get it in? flame away.
EDIT
Nevermind, i figured it out
So what did you figure out? I have the same question. Just bought one of these add-a-circuit thingys to power the switch for my winch power inturrupt kit. The switch worked fine when I just crammed the bare wire into an empty switched fuse recepticle...but now that I wired it with the add-a-circuit...nothing...
do you have to have a fuse plugged into the side of the add-a-circuit? Is it a special fuse or just the same as the others? ....and which set of holes do you put the fuse in (there are two sets) if you do need one? THANKS!
Ling-Ling's Revenge
2008 TT: BudBuilt skids, Toytec 3" lift, RA front bumper, PIAA 510 fogs, WARN M8000 winch
FJ Bruisers | Olde North State Cruisers
