Old 06-28-2008, 01:46 PM   #53 (permalink)
Tankota
Tankota's Avatar
Member Number: 3884
Re: MAF Sensor Maintenance
wrigman previously said: View Post
Look at the sensor, there is a hole in it. THAT IS NOT THE SENSOR!! The sensor looks like a match stick.
That is not correct. The sensor that looks like a match stick is the temperature sensor, it reads the incoming air temp. The air flow sensor is in fact down in the holes, it's two very thin sensor wires that are stretched across the opening down there.. These are the platinum hot wires. Do not stick anything down there! The can break real easy, and then you are SOL. Most of the problems with the MAF are these two thin wires getting coated and gummed up... You want to carefully spray MAF cleaner down there and get those wires cleaned. Make sure what ever cleaner you use is an electronics type cleaner, and is rated "plastic safe". Best bet is the CRC MAF cleaner spray that can be found at most auto parts stores. DO NOT USE carb cleaner or brake cleaner.
David Hale
2007 Sun Fusion FJ Cruiser - Project T2
Demello Sliders, Icon (DR) Front coilovers, Deaver Rear 2.5 Coils and rear Bilstein 7100 shocks, All Pro HD rear links, 34" Goodyear MT/R's, Bandi Mount, Demello front bumper w/winch, Demello Front Skid plate, 4x150W roof mounted KC's and safari lights, ATRAC-Hack.
2007 Yamaha Grizzly 700fi 4x4
2007 Yaris S-Sedan (DD)
http://www.offroadingadventures.com
TTORA-Socal member #38 TTORA Forum
Trail Crew Member
Tankota is offline   Reply With Quote
