Old 07-21-2008, 02:58 PM   #1
action381
action381's Avatar
Member Number: 6681
PIAA 510 install w/OEM AUX switch
I have read and search over all of the post regarding installation of the OEM AUX switch. Frankly I do not understand the majority of them. Most of the diagrams are in pdf form talking about what each port represents. All I am trying to do is use the PIAA wiring with the AUX light switch. I am trying to remove the wires from the OEM wire harness and use the PIAA connector. I saw where Barefoot did this, I believe.
PIAA 520s hooked up with OEM aux switch & harnesses
Does anyone know if I can pull the 3 wires out of the OEM harness and insert them into the PIAA switch harness. Also what wires would go where?
action381 is offline   Reply With Quote
