Old 08-04-2008, 08:52 AM   #1
NCFJ
NCFJ's Avatar
Member Number: 8585
Built my front tube bumper w/2" receiver
A while back I built a 2" receiver to accomodate a winch on a multi mount for the front of the FJ. It worked out well but I still wanted a different bumper. So I built a tube bumper and incorporated a 2" receiver into it. It can also be built with a winch plate as well.
2” Receiver Tube Bumper Specs
Specs: As built with 2" receiver
Weight-91 lbs
Top Tube-1 1/2" .188 wall(3/16") DOM tubing
Second bar-1 1/4" .188 wall(3/16") DOM tubing
Main verticle supports-1 1/2" .188 wall(3/16") DOM tubing
4 side supports-1 1/4" .188 wall(3/16") DOM tubing
Main mounting plates (4) 1/4" steel plate
Main cross bar-at bottom just above stock tow hooks- 1 1/2" X 2" .188 wall square tubing
Receiver-2 1/2" .250 wall square tubing
Receiver support- 1/4" plate steel welded to rear of receiver, 90degree supports behind it (tough to see in photos). 1 1/4" .188 wall DOM tube Hoz. connected to two main vert supports and welded to bottom of receiver. Two Vet.1 1/4 .188 wall DOM tubing welded to sides of receiver and HOZ 1 1/4 .188 wall DOM tubing above and below. One 1 1/4" .188 wall DOM tubing angle brace below receiver attached to 1/4" steel plate
Skid plate-1/8" plate runs from bottom of 1 1/2 X 2" square tube to front cross member of frame.
Top Cover-1/16" steel plate welded to top bar and fitted under grill bezel and body around to fender flares.
$875.00 plus shipping
I have recently been getting many questions about the multi mount and wiring for the rear of the vehicle. The links below are to the multi mount and the wiring. Both are from Warn.
Warn Industries - Mounting Systems: Winch Carrier
Warn Industries - Rear Quick Connector Kit
"The next best thing to playing and winning, is playing and losing"
Religion is for those who are afraid of going to Hell
Spirituality is for those who have been there.
NCFJ is offline   Reply With Quote
