Re: I want to lift it, not sure.
You will have no problems with a 3-inch lift. I have an OME setup with 886 heavy springs in front and 895 mediums in the rear with the ARB shocks. My ride actually improved. The FJ has a smoother ride and handling is much more positive.
Yep, you've heard whining and complaints on OME lifts, but they when investigated the cause is improper installations or use of the wrong springs for load, etc.
I would not, I repeat NOT do a spacer lift. IMHO, they are unstable.
cheers,
dale
Happy Trails!
TLCA #17625
LOS TRES AMIGOS IN MEXICO
TITANIUM METALLIC--A/T
ARB Bumper - Warn Winch - OME Heavy 886/895 - Bandi Mount - All-Pro Lower link skids - Bud Built skids - Snorkle - Toyota prefilter (cyclone air filter) - Optima Yellow Top Battery - Painless Dual Battery Control System - Scuba Driver Mod - Kenwood DNX 7120 GPS - A-TRAC mod - 110v add-on - Rock Rails - Rear Locker - Roof Rack - BFG TA/KO's - ARB Fridge/Freezer - '08 side visor mod - Royal Purple fluids - E3.68 Spark Plugs - All Pro Rear Bumper - All Pro Lower Links - M-Pac rear and side mounts
To be continued...
