» Auto Resources
» Sponsor Links
»Garage Storage and Cabinets
Thread: Low crawl ratio
Old 09-03-2008, 02:02 PM   #3 (permalink)
Fjamming
Super Moderator
Fjamming's Avatar
Member Number: 6623
Re: Low crawl ratio
In addition to what CaliChoas has posted, you need to be mindful that Atrac will not work once you're on the clutch. In order to craw at 1mph without being in the clutch, you'll need a dual case setup like the Inchworm Lefty or Marlin Cralwer's MC11 (which is status unknown at the moment).
Crawl Ratio-Wikipedia previously said:
Crawl ratio is a term used in the automotive world to describe the lowest gear ratio a vehicle is capable of. The crawl ratio of a vehicle is affected by the entire drive train, including transmission, overdrive differential and tires, and can vary greatly between automobiles.
The lowest gear of most vehicles is either first gear or reverse, but when referring to crawl ratios, only first is normally taken into consideration. The crawl ratio is aptly named, for when a car is using its lowest possible gearing, it moves the slowest at a particular engine rpm. The usefullness of a high crawl ratio is to provide the driver with the greatest possible torque to pull large loads or climb steep inclines. Crawl ratios are most often used in the context of large SUVs or trucks and off-road vehicles.
Sandoo Blue FJ
SoCal Events Calendar
Fjamming is offline   Reply With Quote
