» Auto Resources
» Sponsor Links
»Garage Storage and Cabinets
Old 07-09-2006, 09:34 AM   #8 (permalink)
sbechtold
sbechtold's Avatar
Member Number: 639
Re: OME install prices/quotes, how much?
FJ Cruiser #8 previously said:
hey sbtech,what r u using on the rear? 895springs and n141shocks???
I am going with a more firm (heavy) spring setup in the rear. I will be installing 896 springs with N142 shocks. There are couple of reason why I chose to go with the heavier springs.
1.) I plan on installing an aftermarket rear bumper w/ tire carrier, hi-lift jack and gas cans when available which will probably add 100+ lbs to the rear of my FJ.
2.) I upgraded my wheels and the new wheels weight ~30 lbs more that the stock wheels (think: weight of the spare on the rear).
3.) I have a hitch mounted dirt bike carrier that I use to transport my CRF450 and a gas can.
4.) I have a boat that I might some day decide to tow with the FJ (unlikely, but did not want to rule it out).
5.) I will be doing some extended camping trips with my boys where the FJ will be loaded up with gear and I did not want to over load the suspension.
With that understanding of my requirements, I chose the 896/N142 setup. I would rather have a more harsh ride when unloaded, then to over the suspension. BTW, if you haven't already read all the threads/post from "Valkyrie" (Chris) at Toyota of Dallas, then I suggest you read them. There are a ton of little nuggets in his posts that will help you decide which specific configuration is correct for you. If after reading his posts you still have questions - send him a PM and ask. Chris is great to talk to and has a wealth of knowledge on this topic.
Here is one of the threads that will help you decide. ome suspension available?
07 FJC, Ti Silver, 4x4, AT, SFA
Projects: Solid Axle Conversion | SAC’d FJC - Phase 2 | Inchworm Crawler | Internal Cage | Tube Doors | Tire Carrier
Member: TLCA | BRC | CA4WDC
sbechtold is offline   Reply With Quote
