I've been considering adding a similar setup. I was thinking of adding my Masterflow MF1050 with an airtank and then piping air to the rear of my FJ. This unit works fast and has given me excellent performance!
I also considered this unit but I haven't made any decision yet. Here's the link:
Wolo HIGH-OUTPUT 110-PSI 12-VOLT AIR COMPRESSORS AND STORAGE TANK KITS : JC Whitney: Auto Parts & Accessories
Or this one:
Air Lift QuickSHOT On-board Compressor & Air Storage : JC Whitney: Auto Parts & Accessories
Try this link for air compressor comparisons:
Tire Inflator Comparison
You might consider Straun deflaters. They can be preset to a particular air pressure. I have a set of these and they work fine for me.
Another option is the ARB deflater. It removes the valve stem and you can air down in a hurry. It allows for easy checks of tire pressure as it airs down your tires.
Use the forum search function to see more discussions.
What part of MO do you live in? I'm in Richland, just west of the Fort.
Hope this helps!
Cheers,
dale
Happy Trails!
TLCA #17625
LOS TRES AMIGOS IN MEXICO
TITANIUM METALLIC--A/T
ARB Bumper - Warn Winch - OME Heavy 886/895 - Bandi Mount - All-Pro Lower link skids - Bud Built skids - Snorkle - Toyota prefilter (cyclone air filter) - Optima Yellow Top Battery - Painless Dual Battery Control System - Scuba Driver Mod - Kenwood DNX 7120 GPS - A-TRAC mod - 110v add-on - Rock Rails - Rear Locker - Roof Rack - BFG TA/KO's - ARB Fridge/Freezer - '08 side visor mod - Royal Purple fluids - E3.68 Spark Plugs - All Pro Rear Bumper - All Pro Lower Links - M-Pac rear and side mounts
To be continued...
