» Auto Resources
» Sponsor Links
»Garage Storage and Cabinets
Old 09-25-2008, 09:13 AM   #52 (permalink)
VooDoo1
Member Number: 7942
Re: Dash Gauge Pod / Cluster Installed Without Dash Swap
My 2007 FJ did not have the gauge pod connector in the existing wiring harness. I had to purchase the harness listed. It has been about a year since I installed the gauge pod, but if I remember correctly, the connector for the gauge pod is approximately 1/2" x 1/2" square white connector with (I believe) 4 wires coming from it. I keep kicking myself for not taking pictures. I don't recall having any unused connectors in that area. If you can post a picture of the connector you have, I will be glad to let you know if it looks like the correct connector for the gauge pod. Or if you order all the other parts (less the harness) you can check the gauge pod against your connector. If it fits great, or if not you will have to order the harness I listed. Special ordering the harness should only delay your install a few extra days. Let me know if you need any other info.
VooDoo1 is offline   Reply With Quote
