Old 07-15-2006, 10:58 AM   #10 (permalink)
TBarnaby
Member Number: 1271
Re: Upper Control arms
Toyotatech1 previously said:
Heres Jim_D FJ
I have installed the Revtek kits and OME using stock uca and they will not aling to factory specs. I can get the camber within specs but the caster does not into the green with the cams on the eccentrics maxed out. Jim had Donahoe fronts and I installed his Total chaos uca put it on the alignment machine camber and caster were perfect all I had to do was adjust the toe.
Since you work on these maybe you can answer a question for us. Why is it different to align an FJ with a spacer lift vs coilovers? Haven't the control arms moved the same in both cases (lifts being equal).
TBarnaby is offline   Reply With Quote
