Old 11-18-2008, 07:52 PM   #171
CactusJK
CactusJK's Avatar
Member Number: 1157
Re: The "No Cut" A-TRAC + RR DIFF Hack.
My Scangauge had 2 codes. I cleared them and the lights went away. I did a rescan and everything was good.
Swingshiftworker previously said: View Post
If you don't need to know "why" you got the check engine light (for some reason, all the other lights come on when that happens too when that happens), just disconnect the positive clamp on your battery, wait 2 minutes and reconnect.
If it's a minor or temporary problem, the check light should go away If not, you've got a "real" problem and need to buy a OBD reader or go to your dealer/shop to find out what the OBD code is to determine the problem.
Good luck!
K7JNZ
CactusJK is online now   Reply With Quote
