Old 12-03-2008, 11:49 AM   #1
rachad6
rachad6's Avatar
Member Number: 23275
Send a message via MSN to rachad6
ARB bull bar problems, HELP
Hey guys
I installed my arb bumper with an M8000 winch
All was well, after taking it offroad I noticed that the bumper was touching the body work under the turn signal on both sides
I contacted ARB they said that I need to lower it and that it should be minimum 5 mm between the lowest point of the bodywork under the turn signal and the bumper
They were right I had it at 3mm so I dropped it to 6mm to be on the safe side and tested it on a forklift by flexing the suspension all was well
Now it’s only contacting the body on the passenger side, peeling off the paint(picture 1)
I called ARB they said that it should be adjusted left to right
After measuring it I got 12mm on the driver side between the plastic over fender and the wing of the bull bar(picture 3)
And I got 10mm on the passenger side(picture 2)
Meaning that I need to move it 1mm to the passenger so I would have 11mm on both sides
Will 1mm make that much of a difference
Knowing that I measured everywhere else and it all seemed ok and I sent pictures to ARB and they said it’s ok except for left and right
I need any feedback from anyone who had this problem and can u tell me if its centered on your trucks and if you can provide some exact measurements
Thank you
arb-bull-bar-problems-help-dsc00400.jpg  arb-bull-bar-problems-help-dsc00402.jpg  arb-bull-bar-problems-help-dsc00403.jpg
rachad6 is offline   Reply With Quote
