Old 12-24-2008, 09:21 AM   #6
OTRATTW
Member Number: 17469
Re: Electrical Switch Help
Regud previously said: View Post
Hmm, thanks for the tip and a place to buy switches. The problem is that I have less than 1 square inch to place the switch. These switches look bigger. Do you know the size of their switches?
The V-series rocker switches won't fit. They require a .830 X 1.45 hole.
Check out Del City - Wiring Products and Professional Electrical Supplies . There might be a minimum order requirement which is easily met should you need wiring or connectors.
OTRATTW is offline   Reply With Quote
