Old 12-31-2008, 11:33 AM   #10
mitchm
mitchm's Avatar
Member Number: 20196
Re: Is it the Autostart Sys. causing check engine light & loss of Traction Control sy
TinCan previously said: View Post
This is the answer. To better test that this is it. Put your key in, but don't turn it. now remote start the car... it should work normal. This is because of the 08 and up immobilizer, sounds like the install is missing the mod. box that needs one of your keys or a toyota bypass box.
I will give this a try, however I may have to disconnect the battery first to clear the lights, and its a bit cold out there -9*F. I will post the results.
Food for thought; The auto start does not cause the lights to come on every time that I use it, but the lights only come on if the Auto start has been used.
mitchm is offline   Reply With Quote
