Old 12-31-2008, 11:47 AM   #11
TinCan
TinCan's Avatar
Member Number: 16596
Re: Is it the Autostart Sys. causing check engine light & loss of Traction Control sy
mitchm previously said: View Post
I will give this a try, however I may have to disconnect the battery first to clear the lights, and its a bit cold out there -9*F. I will post the results.
Food for thought; The auto start does not cause the lights to come on every time that I use it, but the lights only come on if the Auto stat has been used.
Right, the remote starting, throws the lights because there is a chip in the key that is NOT being read when the car is started. This is why you shouldn't have the lights coming on with a normal key start.
TinCan is offline   Reply With Quote
