Old 07-25-2006, 12:37 AM   #120 (permalink)
fjsmurf
fjsmurf's Avatar
Member Number: 107
Re: Toyota's Special Service Campaign (SSC)--60D For 2007 FJ Cruiser
TMS USA previously said:
Judah, call the Customer Experience Center at 800-431-3331; Let them know that you are not getting the campaign service as expected from the dealers you are visiting--and let them know that TMS USA on this forum says that there seems to be some sort of conflict between what you are being told at the dealerships and the actual provisions of this recall. Are the original tires on your FJ?
No need to go to the NHTSA--We've already done that. You either have the affected tires or you do not have them. If you have them, they are removed, destroyed and replaced with new ones of identical make. There is no inspection involved.
TMS USA,
2 of the 3 dealers I called said they will inspect and replace only the damaged ones, not all 5 tires. I rec'd the letter, my VIN is in range and my tires serial # is in range too. It's one thing you guys are not willing to give the customers option to upgrade at the same time but more importantly, I do not want to be driving with a mix of new and old tires.
Is there a way you can attach an official letterhead stating what you have said above so at least we can show it to the dealers?
TIA
fjsmurf is offline   Reply With Quote
