Old 01-07-2009, 01:50 PM   #21
api510
api510's Avatar
Member Number: 17306
Re: Is it the Autostart Sys. causing check engine light & loss of Traction Control sy
TinCan previously said: View Post
You need to add diode, so that starter 1 doesn't backfeed. http://www.fjcruiserforums.com/forum...rs-1304dp.html
This could help end a lot of this, I wrote this post awhile back for 07's but still do-able with a toyota bypass box
My installer told me that a bypass would be needed for the remote start to work on mine too. From what I understand, the bypass does away with your transponder key altogether. You either need a new key or the installer said that he could take apart my existing key and put a new cover on it (only so it wouldn't be so bulky).
api510 is offline   Reply With Quote
