Old 01-08-2009, 07:55 PM   #1
rob1217
Member Number: 24553
Visibility Problems????
Three weeks into FJ ownership and I'm not experiencing all of these so-called problems with visibility I keep reading in the reviews. Yes the C-pillars are large, but with proper use of side mirrors you can negate the disadvatage from the rear corners. In case someone needs a tip; move your side mirrors out where you can barely see the side of the vehicle and you will be just fine. In fact you will almost be able to see something as small as a Yaris beside you on the highway. The extra height really helps add more side visibility than you can get in a car lower to the ground. This is coming from someone who's driven mostly cars for the past 15 years. The visibility "problems" are few and far between for me.
rob1217 is offline   Reply With Quote
