Old 01-08-2009, 08:17 PM   #6
fj6high
fj6high's Avatar
Member Number: 17218
Re: Visibility Problems????
rob1217 previously said: View Post
Three weeks into FJ ownership and I'm not experiencing all of these so-called problems with visibility I keep reading in the reviews. Yes the C-pillars are large, but with proper use of side mirrors you can negate the disadvatage from the rear corners. In case someone needs a tip; move your side mirrors out where you can barely see the side of the vehicle and you will be just fine. In fact you will almost be able to see something as small as a Yaris beside you on the highway. The extra height really helps add more side visibility than you can get in a car lower to the ground. This is coming from someone who's driven mostly cars for the past 15 years. The visibility "problems" are few and far between for me.
I think you will find just being very aware of whats around you and being aware of the blind spots will prevent alot of mishaps.
I use the little stickem mirrors inside the mirrors. I also installed a wireless cam on the rear right side bumper that I can see that little compact in my right rear side blindspot.
Do not make sudden lane changes to the right !!! You will most certainly crash somebody over time.
I've been lucky several times to avoid a collision, Believe me you I have recieved the Middle Finger more than once
Just try like heck to be aware of whats around you at all times, It seems like people these days have a death wish and are looking for a Compensation Ticket.
If your lifted like me the risk is tripled!!!!
Fabtech 6" Lift + OME 3" 20" BBS rims Nitto 35"s AT,1.25 spacers,Bushwhackers, VR3 The Toy Outfitters bumper ,55 watt fogs,TG sliders, Manik tailight guards, Stallion Light bar,55 watt Baja lights, Cobra 19 SXIV PA, Bandi 4' fire stick, K & N filter, Locker on demand, ATrac hack, VSC & DRL switches, TRD Cat back, Scuba Mod, Garmin Nuvi 200 BlueSeas 6 fuse Interior: leather seats, dual arm rests, dual factory DVD players, Diamond interior trim, Source 10lb, Rubber mats. TT and FJC Badge.
fj6high is offline   Reply With Quote
