Thread: Ham AND Cb
Old 01-11-2009, 08:15 PM   #2
Recon FJ
Recon FJ's Avatar
Member Number: 21168
Send a message via AIM to Recon FJ
Re: Ham AND Cb
stevemacfarlane previously said: View Post
I already have a Midland CB setup with the Bandi mount. Can I use the same coax and connectors to operate a portable hand-held HAM unit. Looks like I'll need a different antenna mounted to the Bandi, right?
Generally speaking, yes you need a different antenna and the Bandi may not accomodate it. But there are a lot of variables at work. Depending on the handheld HAM, you may not see as much benefit of an external antenna as you will with a CB.
In fact, if you are operating 2M and/or 440 (70cm), I don't think the trouble of an external antenna is worth it. Most handhelds will hit the local repeaters just fine. For those that they can't reach, an outside antenna won't be enough. You'll need more power for that.
For tail runs, convoys, Field Days, and the like, handhelds are fine as equipped.
If you are making the investment, there are some very nice "modular" 2M/440 units on the market from 50 to 70 Watts. The face plates are detachable and you can install the transceiver just about anywhere- under a seat, against the firewall, in the rear... The options are endless.
You will need a separate antenna and again, there are lots of choices. Larson and MFJ even make through-the-glass antennas that do not require drilling a hole. Most will argue that a vehicle grounded antenna is best, and they are right from a signal-to-noise ration and for achieving near perfect SWRs.
My advice is stick with the antenna the handheld comes with if you are fixed on getting a handheld. If you anticipate using the HAM frequently, get a mobile unit.
Hope this helps.
Recon FJ is offline   Reply With Quote
