Old 08-02-2006, 12:20 PM   #25 (permalink)
John
John's Avatar
Member Number: 3675
Re: Cobra 75 WXST and Bandi Mount Install
bigbill25 previously said:
For the antenna cable, you can run it down the A-pillar. That outer piece is just bolted from the inside by a bolt that is under the grab handle on the inside of the A-pillar... Hard to explain in words. I'll have pictures of this when I do my rack light wiring, but that is still a week out...
Your big issue will be getting a good ground on the rack for the antenna. I would actually recommend against mounting it there...
--Bill
Curious about the ground issue you mentioned. I would not have thought of that, what is the specific problem? That Bandi mount really looks like the way to go though, I may look into going that direction.
John is offline   Reply With Quote
