Old 08-05-2006, 03:47 PM   #1
Ospreyguy
Ospreyguy's Avatar
Member Number: 3301
Install of VSC cancel switch
I was inspired by san antonio FJ to do this mod from his post at how to disable VSC (it works).
So I started by unplugging the VSC and stripping the e-tape and cover to expose the wires.
Then I found access into the cabin through a removable grommit (careful I dropped it as it tends to pop out).
I cut the purple wire and spliced in 2 lengths of wire about 3 feet each and fed them through the hole. the backing you see in the hole is just the padding inside the cabin under the dash and can pull back easily.
I used a toggle switch as they are the easist to install, attach the wires and just drill a 1/2" hole then screw it in.
It's kind of hard to see here but I cut a small notch in the grommit before I replaced it so the wires could feed through. Clean up the wiring with some zip ties and some e-tape and you are all set. Let me know if you have any questions.
A/T - Black Diamond
Fair Tax Now!
phinman previously said: View Post
Insults you are not good at zero!!
Ospreyguy is offline   Reply With Quote
