Old 08-09-2006, 11:58 AM   #1 (permalink)
Kansas Law Dog
Kansas Law Dog's Avatar
Member Number: 931
To the First 22,000 Owners - Toyota should Thank You
Upon reading that Toyota stated that there will be a $200 per vehicle increase beginning with shipments arriving at port on and after 2 September, I came to the conclusion that the early buyers earned a well deserved windfall. Think of all the valuable consumer criticism and vehicle testing that the first 20,000 buyers have provided to Toyota:
• Discovery of radio glitch for satellite systems, XM and Sirius
• Comments of frame rust at weld seams
• Wet seat belts due to leaking roof rack attachments and/or suicide door seals
• Failures of gas tank gauge level indication
• Poor tire mounting procedures
• Fit and finish of passenger air bag cover
• Roof rack cross member rattle due to improper fit tolerance
• Premature wear of seat fabric
• Proper seat latching in slider rail when adjusting seat position
• Loose lug nuts and failure of lugs when torqued as specified
• Height of vent fitting of rear differential versus maximum recommended fording depth
• Durability of interior plastic materials
• What port installed options are popular and what is not
• What factory built features are popular and what is so-so
It is probably safe to say that there are proportionally more hardcore off-roaders in the first 20,000 sales than there will be in future sales, but much is learned from the desires and critiquing of this group. I’m sure that Toyota is or will be evaluating things such as:
• Increasing wheel well clearances and trim frames to accommodate larger tire sizes
• Skid plate protection (trailing arms, transmission, gas tank, etc)
• Exhaust routing and low hanging cross over pipe
• Optional bumpers with winch capability
• Better windshield glass that is more resistant to damage
• Final engine-to-axle ratios for crawl speeds in low range
• Use of A-Trac with rear differential lock
• Temperature gauges for engine, transmission and transfer fluids
• Transmission cooler with tow package option
It is true that many FJ Cruiser buyers will rarely drive off the pavement, so Toyota will review amenities that fall into the creature comfort area (I have listed items that are 21st century common place, but not luxury class):
• Map lights
• Rear door windows
• Rear quarter panel vents
• Mirror heaters
• Ample coverage sun visors
• Locking gas cap door
• Additional 12V connections
• Sunroof
• Inside release of rear window and rear door
Kansas Law Dog is offline   Reply With Quote
