Click here for:
Sizes, Specs, and Pricing on The Nitto Trail Grappler M/T
The following sizes will be available by years end:
LT285/70R16 E 125/122P - Released
LT295/70R17 E 121/118P - Released
35x12.50R17LT E 121Q - Released
LT285/65R18 E 125/122Q - Released
LT295/70R18 E 129/126Q - Released
35x12.50R18LT E 123Q - Released
LT295/55R20 E 123/120Q - Release
LT295/65R20 E 129/126Q - TBA
LT305/55R20 E 121/118Q - Released
35x12.50R20LT E 126Q - Released
37x12.50R20LT E 126Q - Released
37x13.50R22LT E 123Q -TBA
38x13.50R24LT E 123Q - TBA
The all-new Trail Grappler™ M/T blends some of the off-road performance of the Mud Grappler™ with the on-road comfort of the Terra Grappler™ to create a tire that is both aggressive and quiet. For off-road performance, the sidewall combines a 3-ply high turn-up construction with a thick rubber compound that cushions the tire and helps prevent punctures. On the tread surface, the blocks are configured to provide additional biting edges that command lateral stability and enhance forward traction. For on-road comfort, Nitto's engineers used advanced sound analysis equipment to reduce the noise levels commonly associated with off-road tires. The internal construction and tread design also help optimize treadlife. Two wide steel belts provide a stable base for the tire and increase tread strength. This advanced construction provides optimal uniformity and reduces irregular wear.
Nitto promises the Trail Grappler MT will be the next best thing to hit the Grappler line up. For those of you who love the Terra Grappler but want a little more bite and off-road performance without stepping up to the Mud Grappler, this tire is for you. Nitto manufactures their Grapplers with the most up to date manufacturing technologies. Nitto uses segmented molds that fit together like puzzle pieces, and continuous wound steel belting. These two manufacturing processes alone make a huge difference when it comes to balancing. They also help to dramatically reduce the tires chance for tread separation. Add to these, Nitto's highly sophisticated rubber compounds and the fact that Nitto builds 90% of their Grapplers in the USA and you have a winning combination.
Click the image below to be redirected to Nitto's interactive site for more detailed information on the Trail Grappler M/T.
Reviews & Wright Ups
Peterson 4 Wheel and Off-Road Trail Grappler Article
