Can I hang a T-Case off a 4X2 transmission?
3K views 5 replies 5 participants last post by  LandCruiserSteve
#1 ·
Does anyone know? I hope to buy a 4x2 cruiser manual trans, then add a straight axle and an Atlas T-Case.
Any info is appreciated.
#2 ·
Anything is possible if you have the right skills, tools, time and $$$$.
If I understand your premise correctly, you are planning on buying a 4X2, converting it into a 4X4 with a solid front axle by adding an Atlas transfer case and running front drive shaft into the solid front axle.
Really not much different than someone who does the same but removes the front IFS diff. Check out the few solid axle conversions by sbechtold, MissFJ, M&M and you will see what's involved...
