Anyone have a part number for the foot rest to the left of the brake pedal? I broke mine and the closest stealership wants $60 for that piece of plastic, I told em my foot was just fine but I would like to find a replacement.
what if you just made your own. just bend a sheet of metal around it. does it bolt in to something? if so maybe that would work.pardon my lack of smarts......mine is still in tact
Could epoxy one of these on... but, then you are still looking at the same cost the dealership wants. I would try getting a piece of alumnium sheet... drill some holes in it for looks and epoxy the bugger together.
The foot rest snaps down onto plastic pegs that are mounted on screws. The screws mount from the bottom through the wheel well and the heads of the screws appear to be covered by the wheel well sealant so ya cant take em out...cant even find em. The clips on the back of my foot rest came apart and it doesnt appear that they will be going back together. Pulling one from a junk yard doesnt seem to be a possiblity because it looks like you have to break it to get it off. May have to bite the bullet on this on at some point.
THe Dead Pedal comes out if you pull it loose. The "Screws" are actually an odd sized threaded stud that is welded in at the factory. My Dead Pedal broke completely off a while back. I have made a new dead pedal out of aluminum. The only bad thing is that the threading on the studs only work with the square plastic nuts that the original snaps into. I will post pics of what I have built in a bit. I will try to draw up some plans too.
Grease Monkey @ SoCal FJ Cruises has his CNC Machined Dead Pedal available for purchase. It's designed to work with your existing pedal after the posts have broken.
Pics of Grease Monkey's CNC Machined Dead Pedal. I've ordered mine, but it will not be shipped until Monday.
Pictures are courtesy of Grease Monkey. Note: Pics are for the auto version.
Modified original dead pedal with aluminum fix pedal.
Aluminum dead pedal attached without modified original.
Quick pics of the manual dead pedal and my OEM that was used as a template.
Related Threads
Toyota FJ Cruiser Forum
3.7M posts
122.7K members
Since 2005
