Old 02-01-2006, 01:14 PM   #8 (permalink)
LRJ4X4
LRJ4X4's Avatar
Member Number: 93
Re: River/Water Forging
You will float at some point then you need to flood the interior to "sink" it and hope you get traction before it or you drown. You will need a snorkel and extended differential breathers and or tranny breather. You will also need a radiator fan kill switch to prevent the fan from eating the radiator, the fan blades bend when they hit water. Most of the time when the computer hits water it's game over so you will want to find out where that is. Also if you get the 6speed do not shift while in water, pick a gear and leave it in gear.
This is serious warranty voiding abuse and you will need do a full lube and fluid service afterwards to make sure nothing sucked water. When a hot differential or transmission hits cold water it creates a vacuum so don't even think about it without extended breather tubes.
Do yourself a favor and buy a old diesel beater truck for this type of stuff or get a boat
LRJ4X4 is offline   Reply With Quote
