Old 08-28-2006, 02:49 PM   #1 (permalink)
Toyotatech1
Toyotatech1's Avatar
Member Number: 1637
Send a message via AIM to Toyotatech1
FJ Alignment Specs
2007
FJ Cruiser 4X2
FRONTSpecificationNeg. TolerancePos. ToleranceLeft Camber-0.57°0.50°0.50°Right Camber-0.57°0.50°0.50°Cross CamberLeft Caster3.57°0.50°0.50°Right Caster3.57°0.50°0.50°Cross CasterTotal Toe0.08°0.17°0.17°Left SAI12.92°0.50°0.50°Right SAI12.92°0.50°0.50°
2007
FJ Cruiser 4X4
FRONTSpecificationNeg. TolerancePos. ToleranceLeft Camber0.15°0.50°0.50°Right Camber0.15°0.50°0.50°Cross CamberLeft Caster2.82°0.50°0.50°Right Caster2.82°0.50°0.50°Cross CasterTotal Toe0.08°0.17°0.17°Left SAI12.35°0.50°0.50°Right SAI12.35°0.50°0.50°
When you get the alignment done the caster will more than likelly not go back to within specs. What you want to do is get camber as close to center as possible and have the right front caster be .40-.50* greater than the left side this will insure that the vehicle tracks straight and will have no tire wear issues as long as tires are rotated properlly.
Toyotatech1 is offline   Reply With Quote
