Re: Here is why part time 4WD should never be used on dry pavement
Isn't it saying that if you have a center diff and it isn't locked then it's ok?
"...and center differentials have been employed since then to correct the problem"
"The extreme tension and pressures caused by the absence of a center differential (or caused by a center diff that has been locked)..."
