Front and rear bumper wings removal
41K views 14 replies 14 participants last post by  Konig
#1 ·
Hey guys
I want to remove the front and rear bumper wings to paint them. Can you tell me if I can remove them without removing the entire bumper?
#2 ·
I've seen threads on here of people just masking around the wings and painting. Seems like they had no trouble doing that. :bigthumb:
#3 ·
Just out of curiousity for those that spray painted the wings, how often do you guys have to repaint? Does the paint chip off easily?
That was one of my reasons for taking the wings off and having it painted professionally. I rather have it done one time and forget about them.
#4 ·
The easiest way to remove them is to remove the bumpers. It doesn't take much and I don't think you can get to the wings with the bumpers on. I painted mine about a month ago and they are holding up quite well. It's all in the prep work.
#5 ·
I got my fronts off without removing the front bumper...took about 20 minutes total. the clip is a weird little thing, push in the center, slide it down. I used a little screw driver to depres the center whle fiddling with my other finger. One hand for each side (left on the right side, right hand on the left side).
#15 ·
Great idea!! I've been searching and searching, trying to figure out how to take these things off. Got a few clips out of one but couldn't get to all of them. The first one came off super easy at the Anaheim airport on a pole. So I'm actually going to use this suggestion. Will let you know how it works, lol.
#11 ·
I actually pulled my fronts off this afternoon :)
No problem doing it with the bumper still on, just lie on your back and look up...you'll see 6 white plastic clips. You'll need to depress a center tab to slide them out (An awl or sharpened screwdriver works excellent for this, as you can push in the tab and slide the clip at the same time), and once you have the 6 out, just give it a good pull.
#12 ·
They were easy to remove but not worth the trouble. I posted this in the other thread mentioned earlier:
"I attempted this mod tonight but scrapped it. I ordered the same plastic you used and found it way to thin and I couldn't get it to stop curling up. It also has to be so far pushed out to cover the holes that it was impossible for it to not look wavy. I think I'm going to have to make something out of mdf, cover it with the vinyl, and then paint the whole bumper. This way I can screw it on and it will be nice and solid.
Also, the vinyl was 30 bucks after shipping so I'm thinking that for another 20 it might be worth buying a kit."
#14 ·
You could contact Ordoman. He makes a fitted replacement part out of diamond plate that you can paint. It covers all the clip holes that are left after you remove the wings. Cleans it up nicely.
