fj2play previously said:
Caster does not make a car lean, or sit lower on any side. It is an alignment spec, or more technically the amount of "tilt" the center line of the A arms have to either side off of center.
That's it. It doesn't affect ride height.
Thank You for your response, I do know what caster is... But... My Question Is tho, Why is the right set differently than the left ??? See below....
TY...
Toyotatech1 previously said:
...and have the right front caster be .40-.50* greater than the left side this will insure that the vehicle tracks straight and will have no tire wear issues as long as tires are rotated properlly...
