Re: Tips & Tricks...when in the sticks!
More MacGyver Offroading Tricks
Emergency Tire Reseating Machine- Spray some starter spray ether inside a tire that lost its bead, throw in a lit match and standback as the tire reseats and partially inflates to get you going again. This will only work if you broke a bead but the tire is still intact and just needs to be reinflated but is still aligned on the rim.
