Re: Power for under-seat amp?
There is a pre-drilled hole all ready to go at the firewall with a rubber plug in it. It is right in front of the glove box (top). Perfect for a 4-guage power feed cable to an amp under the passenger seat. No drilling required. Pull the rubber plug out and install a grommet for a 5/16th (may be 3/8") hole. Run the 4G power cable along the door sills. Piece of cake for the power feed. Under the hood, cable tie it across and over to the fuse box outer terminal.
I got an 80amp 'breaker switch' off Ebay instead of using a fuse in-line under the hood. No fuses - nice!
Banksters and Jackals. Note: My sig links are often offensive, raunchy or outside the bubble; clicking means leaving the forum; don't likey?, don't whiney. Only you control your browser. 'Pause' at the beginning of a video allows the buffer to fill and means a more pleasurable viewing experience.
