Re: iPod Setup
Hello,
If you turn off the radio first, and then shutoff the car, will it do the same thing if it wasn't turned off on CD or CD1 mode? Also, how are your dip switches on the module currently set? If you have them all OFF in the UP position, you may want to try the second car switch ON in the DOWN position. However disconnect the DICE module before changing any switches. Let me know if you need any further assistance. Thank You
Best Regards,
Adam @ DICE Electronics
