Old 11-11-2006, 10:39 AM   #9 (permalink)
Valkyrie
Valkyrie's Avatar
Member Number: 1873
Re: spring compressors
chukwagen previously said: View Post
Thanx, guys...that helps.
I think I'll buy 2 pair from sears.
I'll feel better having 4 of them on a spring at a time.
To answer your question, the Revtek kit just has spacers for the rear,not replacement springs.
1. I doubt you'll be able to fit 4 on a single spring safely.
2. I guess you already had your mind set to attempt your first spring compression without guidance before you asked.
3. Disregard the voices of experience if you must, but having swapped out hundreds of springs, I strognly advise you to take your Sears money and give it to Pep Boys instead.
I refuse to do spring work unless it's using my wall mounted spring compressor (with a safety hoop)... I've witnessed firsthand the results of inexperience and/or inattention while using driveway compressors.
You also need to note the alignment of both the cut ends of the coil and the top plate.
Well, you're wrong.
Don't like what you're reading here? Click here
Valkyrie is offline   Reply With Quote
