Thread: backdoor rattle
Old 11-20-2006, 05:11 PM   #42 (permalink)
White Rim
White Rim's Avatar
Member Number: 3435
Re: backdoor rattle
emachine previously said: View Post
Well that sounds like a better plan. Only problem is I dunno what a striker/blind nuts are Does it mean I should be moving the Ubolts, rather than screwing around with making them thicker...
Yes.
You can loosen the bolts attaching the upside down U shaped device which the door latches to (the striker) and then slide the striker inboard slightly and retorque the bolts. The striker bolts are mounted in slot shaped holes, and have nuts on the back which do not need to be held with a wrench, because they slide in a trough that keeps them from rotating (I think )
White Rim is offline   Reply With Quote
