Re: How to eliminate rear sagging when towing?
From my overall experience, air bags are great in relation to this problem. The cheap ease fast fix is the common weight distributing hitch. With this, you can lift the rear wheels off of the ground. If you have a friend with a large camper, you can probably just borrow his and try it to see how it works for you. They do work quite well. The reason that the suspension is a little softer is to give you a good ride and handling quality fot the other 95% of the time that you aren't in towing mode. The weight dist hitch solves both problems at one time.
------------ OFFENSIVE COORDINATOR TEAM LEG ****** STAFF (World Champions) ------------
Life is short---be certain that you were a participant ~ FJ Tribe, 2006
I DO NOT FEEL THAT IN GOOD CONSCIENCE I COULD BE A MEMBER OF ANY ORGANIZATION
WHICH WOULD HAVE A PERSON SUCH AS MYSELF FOR A MEMBER
"THE LAME REMAIN SILENT<for they want for words that speak the truth.Those that say the truth fear not of speaking.as the opinion of the the fools matters not...sayth mike5" ~ mike5, 2006
