Old 11-25-2006, 02:23 PM   #2 (permalink)
Roland
Roland's Avatar
Member Number: 3034
Re: Adjusting The "fj Lean"
Assuming the lean is similar to the FJ40, the only "fix" for the "problem" was a spring pre-tensioner that Toyota came out with. It basically was a plate between the u bolts and the spring that when tight, would bring the high side down a few inches. Adding extra springs, or blocks on the low side wouldn't help any. Please post your results.
Roland is offline   Reply With Quote
