Re: Complete skid plates comparison
I have the All Pro and the plate comes unpainted. I don't have a good pic of it yet but will post when I do. It went on using 6 of the 8 bolts that came out of the stock plates. Very easy to install and all of the bolt heads are recessed.
Use the bubble and plastic wrap that it was shipped with to pad the ground beneath the engine area. Raise the front edge and line the tabs up with the slots in the frame. Insert the two front bolts, twist a few threads in and leave them loose. Using your bottle jack and a piece of scrap wood, jack up the back edge of the plate to the appropriate height to insert the last four bolts. Leave all bolts loose so you can adjust the skid's placement by hand. Go back to the front of the plate and push on it (or tap with a hammer) so the front tabs seat into the slots tighter. Then tighten all bolts firmly. After removing the old plate, the new plate should go on in about 10-15 minutes. It took me longer to uninstall the old plates and clean all the dried muck and leaves out. I'd suggest goggles for that task.
All-Pro bumper, USB links, IFS skid, Extreme LCA links, LCA skids & Bandi mount
Bud Built trans skid/crossmember/gas skid
Metal-Tech red sliders
OME 886/895 springs & shocks
Super Swamper 34" LTBs
Warn 9.5xp/Masterpull line
Demello rear bumper
My PhotoBucket
TLCA #16667 Ga Cruisers - Black Sheep Upstate Cruisers - Safety Officer
Things are more like they are now than they have ever been. ~ Gerald Ford
