Old 12-14-2006, 09:12 PM   #3 (permalink)
Pinker
Pinker's Avatar
Member Number: 6821
Re: piaa 520 wiring help needed
I haven't installed driving lights but I just did fogs and the concept is the same. I used the battery lead going into the fuse box as my source. I tapped into the Low Beam headlight fuse using a Add a circuit from Pepboys. Grounded all earth wires to the Battery ground bolted to inside fender. Ran the switch wires through the firewall (hole just below where the stock cables run) to a switch.
The reason I used the low beam is I woldn't need fogs with high beams on. I can turn the fogs on with just the DRL's running or the low beams.
Pinker is offline   Reply With Quote
