Old 03-12-2006, 09:04 PM   #27 (permalink)
Monster
Monster's Avatar
Member Number: 1113
Re: turn the DRL's OFF!
when the engine is started, a signal from the generator is input into terminal a14 of the body ecu. the wire that carries this signal is green with a gray stripe. it can be found leaving the DRL relay in one of the relay blocks under the hood. The rest is up to you.
I AN NOT RESPONSIBLE IF YOU **** YOUR **** UP!
Monster is offline   Reply With Quote
