Re: turn the DRL's OFF!
Monster previously said:
when the engine is started, a signal from the generator is input into terminal a14 of the body ecu. the wire that carries this signal is green with a gray stripe. it can be found leaving the DRL relay in one of the relay blocks under the hood. The rest is up to you.
I AN NOT RESPONSIBLE IF YOU **** YOUR **** UP!
don't know where you got your info from but it is the gray wire connector E6 pin 14 at the body ecu. Or gray wire connector C2 pin 4 at the generator.
"Excitement? Adventure? A jedi craves not these things." Silent Bob, 'Mallrats'
Drive a legend, drive a Land Cruiser
