Re: Wiring up new KC 130w Daylighters; Need help in wiring.
16 gauge is really way too thin for 45 amps for the ground return. If you are using just one ground return it should be 10 gauge or better.
Alternately you could run separate return grounds for each pair; 14 ga would be ok for 22 amps but 12 gauge would be better
