Re: Those of you with 7' garage door openings.
There's no problem with clearance into a 7' high opening. Just make sure that your opener is adjusted to pull the door past the weatherstripping that's attached to the header of your garage door opening. In fact I measured and I a 3" lift on the FJ will still fit with 33" tires on.
Black Cherry Pearl with every available factory option plus front skid plate, aftermarket alarm/starter, D!ck Cepek FC II 33x12.50x17LT tires. Future is a 3" lift kit, sound system and exhaust.
