Re: FJ Alignment Specs
hmm... well i am not sure how Toyota does alignments but most stock cars that i have seen do not have much if any caster adjustability other than tweaking parts and bolting them down before they come back to their normal resting place. Both cars i owned before the FJ had no caster adjustability. Just toe and camber. the only way to adjust caster was to either get adjustable plates or caster bushings. the GTO has a spacer on the caster bushings that push the drivers side out. I am not sure if this is compensation for driver weight or if what i heard about the tracking to the right is true. I will try to find some pics for you of the caster setup on the GTO.
