Old 03-04-2007, 03:09 PM   #35 (permalink)
Garsgrl
Garsgrl's Avatar
Member Number: 3187
Re: FJ Alignment Specs
Nevada_FJ previously said: View Post
So with a 3" lift what should I shot for on the numbers to be right on?
Does anyone have this info? Im installing the FJ3-FRCC from toytec this week. I would like to know what alignment specs I need to use.
I noticed these were psoted earlier Camber at 0.0 and 0.0. Caster left 2.7, Caster right 2.9 (This compensates for road crown). Toe left 0.05, Toe right 0.05. between adding the positive toe (toe in) and positive caster (lengthening the wheel base). However, I know this was used on a stock FJ with no lift. So, will this also work with the lift?
Or should I just go to the alignment shop with these specs (1)
1. FRONTSpecificationNeg. TolerancePos. ToleranceLeft Camber0.15°0.50°0.50°Right Camber0.15°0.50°0.50°Cross CamberLeft Caster2.82°0.50°0.50°Right Caster2.82°0.50°0.50°Cross CasterTotal Toe0.08°0.17°0.17°Left SAI12.35°0.50°0.50°Right SAI12.35°0.50°0.50°
When you get the alignment done the caster will more than likelly not go back to within specs. What you want to do is get camber as close to center as possible and have the right front caster be .40-.50* greater than the left side this will insure that the vehicle tracks straight and will have no tire wear issues as long as tires are rotated properlly.
Garsgrl is offline   Reply With Quote
